KD-49XE8005 and external speaker
profile.country.GB.title
botty1963
Member
I have had this TV for about 6 months and as I don't have the volume on high, don't watch movies etc I have never felt the need for an external speaker. However, I recently purchased a non-Sony soundbar as it was on a good offer. However, the TV will not find it via bluetooth but my phone/tablet/laptop all do. I tried the optical connection which does work, but you can't control the volume using the TV remote, you have to use the remote that came with the soundbar. So after a few searches via Google I used the aux cable that came with the soundbar as I read that's the only way that you can control the volume using the Sony TV remote, but all that happens there is a load buzzing noise from the soundbar. There are no new updates for the TV so I am at a loss. Any suggestions please?
3 REPLIES 3
EdwinaU
Moderator
Hi there,
We will look into this for you and update the thread when we find more information. Meanwhile, maybe another member will have some tips for you.
Best wishes,
Ed
LightFoot
Specialist
Hi @botty1963
Normal connection is a HDMI cable connected to the TV’s ARC HDMI. If the soundbar doesn’t have a HDMI connection then your choices are very limited. What is the make/model of the soundbar?
Win_88
Specialist
Hi Botty1963,
To my knowledge, your TV doesn't support connecting to a sound bar via Bluetooth in the first place, so I wouldn't consider it a fault on the part of the Sound bar or the TV in this case.
As @LightFoot mentioned, HDMI ARC would be your best chance to get the best quality and features at the same time as the TV supports control for HDMI.
Win_88
