I'm mainly hoping to be able to listen to music with my Plantronics Pulsar 590A headset, which is equipped with a blutooth adapter using a 3,5mm plug, but there is nothing to plug it into on the F200. Is there an adaptor that can make up for the lack of a headset plug on the F200 ? I have been advised by a connexion retailer that a KN-OPTRCA10 converter might do the trick.... If this is a workable solution, will it give good sound ?
Many thanks.
Hello,
Could someone from the Sony team please answer the above query ?
Many thanks.
Hello,
I would like to rephrase my question, since I have been told that the Sony DAV-F200 needs a coaxial/optical to R/L audio converter in order to enable a headset connection. If you agree, can you recommend such a converter ? For instance, would you choose a Konig Electronic KN-OPTRCA10 or a GOYONA DCT - 3 ? Or would you prefer another one ?
Many thanks for your answer.
