I have a Sony HXD890 DVD recorder and last night saw a message on Guide Plus+ about the loss of service from the 1st of January. Apparently this affects 'older' DVD recorders, including the HXD890 and many similar models. It is not being carried any more by analog ITV.
Can anyone shed any light on this? I bought the set with the intention of using Guide Plus+, and there was never any indication that the service would not be continued. I live in an area where it is difficult to get permission for dishes. (Babergh Council are Rubbish). I can apparently use Freeview EPG, but this is not as user friendly as Guide+. What are Sony going to do to help owners of these sets. The sets have only been available since March 2008 so cannot be considered obsolete.
http://www.europe.guideplus.com/en/ASO_UK.html
Hi Sue,
I am in the same boat... same model of PVR and same Guideplus+ problem.
I emailed Sony ... here is the question and reply from sony.
QUESTION
ANSWER
I am pleased to learn that you own a RDR-HXD890 but I am sorry to read of the issue that you have.
Having looked into this matter, I can confirm that the Guide Plus+ built into your model DVD recorder will no longer function on the analogue service after the 31st December 2010. However, you will be able to switch to the Freeview guide, 'Guide Digital' which is built in to your recorder.
It is not possible to update your Guide Plus+ EPG to continue using the guide as this is the old analogue Guide Plus+ System and Bid TV cannot be selected as the host channel. This feature is only available on products with the Digital Guide Plus+ system.
To switch to the Freeview guide, simple perform the following:
Press System Menu
Select Initial Setup
Select EPG type select and choose 'Guide Digital'.
I hope this information is of some assistance. Thank you for your enquiry.
Yours sincerely
George Newton
Customer Information Centre
SONY UNITED KINGDOM
So Sue, it looks like we will have to use the digital EPG and forget Guideplus+.
I have googled this problem extensively and there are many others who are complaining.
All the best,
Michael
I have the same model as sue1512. The difference for me is that I have now lost my GuidePlus+ service and can find no information from Sony as to how to reconnect to the new channel on Freeview supplying it. BidTV is the new host channel, but how do I set it up? I don't appear to be able to select this as a host channel. Any info out there please?
Is there a firmware update on the way Sony?
We have also now lost most of Guide Plus and so have switched to EPG.It is a problem because we live in an area that doesn't pick up ITV, Channel 4 or 5 on digital freeview and so can't now set programmes to record on these channels.
Come on, Sony, we need a firmware upgrade for these HDD recorders to receive the GUIDE Plus data from the digital channel BidTV. Analogue ITV1 is no longer going to carry the GUIDE Plus data from 1st Jan 2011.
You have been shamed by being listed on this list of unsupported receivers:-
We expect better from Sony.
Hi Sue,
QUESTION
ANSWER
Press System Menu
Yours sincerely
George Newton
SONY UNITED KINGDOM
All the best,
Michael
The problem with switching to the "guide digital" rather than "GUIDE Plus+" is that it is very crude and lacks search facility. The GUIDE Plus+ keeps the current channel viewable in the corner of the screen, the "guide digital" does not, etc etc. Come on Sony, release a software / firmware upgrade to allow us to switch the GUIDE Plus+ source over from the analogue to digital tuner. This unit was marketed with the digital √ tick logo. Mine still has the sticker on it! The GUIDE Plus set-up menu even has a section in it to change the source, so the job is half done already. Finish the job and make us happy!
Just got my reply back from Sony 'Customer Services' too.
Dear Mr Smith
Thank you for your recent e-mail.
Unfortunately, Guide Plus + on the RDR-HXD models (analogue) will no longer work due to Gemstar switching this service off. Bid TV can only be set on the new range RDR-DC range of recorders which run on a digital Guide Plus + system.
I am sorry I cannot be of greater assistance on this occasion.
Yours sincerely
Sandip Singh
SONY UNITED KINGDOM
Nothing about a workaround or firmware update - just a tough luck for having a Sony 2 years old in effect.
This really isn't good enough from them.
Your letters of reply from Sony customer services are not really good enough, they just smack of "go away, tough luck". If they were to reply "We have had our engineers look at this problem and there is no way to route the digital information to the Guide Plus+ input without hardware modifications" then I would be satisfied. However, there is no suggestion that they have even looked at this problem.
In this age of fully programmable systems, I would say that there is every likelihood that this could be fixed with a software / firmware upgrade.
Ouch! I'm in the same boat. Recorder not yet 2 years old, yet obsolete? Host channel disappeared about two weeks ago - thought recorder was dying... Also have an issue with digital program numbers all resetting to the same number? Everything now completely manual!
Do we have to buy a new one to get EPG back?
To get the standard EPG back - Press System Menu, Select Initial Setup & select EPG type select and choose 'Guide Digital'.
thanks
