Merry Christmas everybody,
I've connected the ef1100 to hdmi1(arc) on the hx820 ,according to the manual should listen the sound from the tv to the speakers of the ef1100 without the need of an optical cable .
Hdmi comtrol is enabled on both devices ,the hdmi cable is 1.4v ,whats wrong then ?needs another setting somewhere ?
I get sound from the ef1100 speakers only when optical cable is connected between the devices.
Any tip ?
Thank you so much but probably will not be necessary as i ...
,today gave it another try ,disconnected all and then connect the sat box 2 which i had problem loosing sound from the BDV-Ef1100 cause of communication failure as i wrote above ,
Guess what ? worked fine,system audio was on and bravia sync enabled
,then connect the wd live hub ,switched between the devices ,all perfect ..
last i connect the sat box 1 which was the only device that worked with bravia sync before and ...
..now the communication failure appeared again ,i got you haha ..
,plugged the Lindy adapter on ,and all is working now as it should ..
i have bravia sync with all devices and system audio runs automatic when i turn the on the BDV-EF1100 ,without any optical cable on ,iam glad also that the cost for the Lindy's adapter was not for nothing ..
My friend Quinnicus thanks again for all the support !
One question more ,i saw a new Sony product very interesting and iam curious if i can add it to my system and make working together with BDV-EF1100 and my setup ,
is the HT-XT1 all in one sound system ,what you think ?
Hi there
I have double checked the manuals for both devices, they both support ARC. Therefore lets check how you have set it up.
A couple more suggestions:
If all of this checks out, and it still doesnt work - Im out of ideas unfortuately, therefore you might want to think about contacting Sony support (unless another forum member has some ideas)
Hope this helps anyhow.
Press enable, Turn off TV and Bluray player. Then Turn on TV, then bluray player, and see if its there. For ARC to work, it has to be HDMI 1 (on TV). At least I think we are closer on the issue
I have my fingers crossed for you!
(Some really weird issues today!)
Yep, I'd probably call Sony Support tomorrow. I honestly dont know whats going on/or not going on in your case.
