Hello,
is it possible to add a wireless Sony subwoofer to the htx8500? I recently purchased the htx8500 and I find the integrated sub extremely weak even at high settings and it has no punch to it like adding extra base to a normal speaker.
would be great if I can pair it with an extra sub
Hi there,
Hopefully a community member can help.
Best wishes,
M
Thanks but unfortunately No one seems to have a solution here
Hi @mmackieh Unless it was advertised as having a optional wireless subwoofer then no. Sony systems are generally sold as what you see is all you get.
Hi Mmackieh,
I don't think it's possible to pair a different subwoofer than the supplied one.
Cheers,
The_Black_Rose
