Hello friends, wanted to check how to use my TV as a center speaker together with my HTS60 system. I have turned on "Acoustic Center Sync" on my TV but i get no sound when gaming or listening to music, only the home theater outputs sound.
Right now i have connected
PC with HDMI 120hz/4k to TV and
HTS60 with E-Arc to TV
Also curious if there is any equalizer to use with the theater system
Afaik that soundbar doesn’t support this feature (and for enabling it you should have a dedicated cable between the two sets , earc is not enough)
sorry to hijack your question, but as you have the hts60 system
( I'm presuming you mean the one with the rear speakers)
we are thinking about buying it , but are finding it difficult to find out how long the bar cable is that connects to the subwoofer.
would it be possible to let me know the length of that cable, I'm hoping it's around 3m
thanks in advance kenny
