Hi
Have hooked up this sound bar and have two issues
1 - Audio seems to be louder from the right side of the bar, distractingly so
2 - The bass seems to drop out intermittently. It's only for a few seconds or so but enough to be noticeable. It's not a wifi issue as I tried turning our modem off and it was the same
Any suggestions gratefully recieved!
Thanks
Carl
Quinnicus, no worries I spent an hour thinking I was going mad before realised the difference due to the 'H'!
Thanks for your thoughts anyway, will let you know if anything changes
Cheers!
Found this link which sheds a little more light on the issue, its seems the cutout is due to having the 'effect' option enabled. Trouble is the sound is nowhere near as good with this disabled:
http://community.sony.com/t5/Home-Theater-Products/HT-CT260-Sound-Issues/td-p/45693
I have had a similar problem. I purchased this soundbar in January 2014 and the soundbar has never performed properly when EFFECTS are switched ON. The problems I hear are: 1. intermittant drop out of voices especially during low volume scenes with little other background noise. I can only describe it as though the actor has moved away from the microphone temporarily resulting in a word, or parts of words sounding "tinny". This only happens when the EFFECTS are switched on, and it happens whether I am watching TV through the inbuilt reciever (i.e. netflix), watching through Virgin Tivo box, or watching my PS3. It also does not matter whether I have connected via optical or HDMI. The other problem I have is that the subwoofer seems to carry a lot of background noise - like it is too sensitive and is picking up too much ambient sound during scenes. Any suggestions?
Hi there
Have you tried changing the Subwoofer levels? Press AMP, then goto Levels > SW LVL
It may help, it may not.
