When connecting my Panasonic HDD DVD recorder to HDMI 1 I/P the screen on my Bravia TV switches from Wide to normal when playing a DVD. This happens whether HDMI output on DVD is set to either PCM or bitstream. Has anyone any ideas as to why. Thanks.
Hi there
You will need to set the TVs screen settings for the HDMI input that you are using - However you need to do with when using the HDD Recorder. Without your TV model number to confirm exactly where the setting is, I have used these instructions for another TV - which should be very similar.
To do this:
Hopefully this helps
Hi there
The instructions should be very similar to your TV, maybe some minor differences in wordings - but if you give it a go, you should be able to figure it out I think.
Hi there
To do this:
Hi ,
Thanks for this. Sorry I should have said my TV is a Sony KDL-43WD756. Are the instructions you gave in your post correct for this model? If so I'll give them a go and see if it sorts the problem.
Thanks
Hi there
Thanks Quinnicus, tried your solution. All good now.
