I cannot get any sound from the HT-XT3 when connecting to my Bravia KD-49X8005C TV using HDMI ARC. The only way I can get it to work is with the optical cable connection. What could be wrong?
Hi there
Assuming that you have connected it to the HDMI-ARC port on the TV, it could be the HDMI cable itself - so, if the below instructions dont work, try a new hdmi cable.
It could also be a HDMI handshake issue, because you plugged it in when the tv was on. Try this:
Hi there
Hi
Many thanks, turning off at the wall and starting again worked.
Steve
