I get My HT-X8500 working bit when I turn the tv off the tv and bar go off fine but when I switch it back o there is no
soind through the bar I have a dvd player
pluged
into
tue bar which works fine and sounds
great but don’t get any sound
from anything that is going through the tv
You need to have the soundbar plugged into whichever HDMI input on the TV is marked ARC or eARC, which is usually only one of them.
Is this the case? If not, move the HDMI cable from the soundbar to go into that specific port.
