I have got a HT ST5000 sound bar and I'm not sure which 'sound field' is best to use?
Hi there,
Hopefully some community members have had some experience with this.
Let us know how you get on.
Best wishes.
M
Hi ShaGlasgow,
I'd change the sound field based on the content playing. You can find description for every sound field in the user manual on page 29 in the following link: https://bit.ly/2rtu5Op.
Otherwise, if you want to use the default sound settings that the content comes with, put it on "ClearAudio+".
Hope this helps,
Almou_10
