Am I able to connect my Amazon Echo Dot to my sound bar?
The Echo Dot doesn't seem to find the sound bar.
Thanks
Hello @Tassellator, the supported Bluetooth profiles are A2DP & AVRCP. Double check if your Amazon Echo Dot supports any of them first.
