After updating to the firmware a couple of months ago (which was done automatically by the way) I have had no end of issues with the product. Bluetooth audio keeps dropping out, it won't search for wireless networks instead it just keeps searching forever and I need to remove all power from the unit, the sound stops outputting audio when pausing the TV and then resuming. These are just some of the issues we have faced. I have reset to factory defaults but still have the issue.
I then updated to another firmware that was released this week and now the system won't boot properly. I get "------" on the display and nothing appears on the TV. I have been advised to take it to a sony repair centre but the closest is 20 miles away and they are closed on weekends.
Sony customer support has been terrible!
My warranty has expired so I don't know where I stand, but surely Sony should fix it due to their borked firmware update. Is there a way I can try another firmware update without being able to access the menu on the TV?
Did you get anywhere with a fix?
I've also had the same troubles as you. The bar has been nothing but a massive disappointment for the money! No part of it has ever worked correctly at one time and it's now not booting simialr to yours after trying to update the fireware. Wish I've never touched it after it broke on the last update too. Really can't be bothered with taking it for a repair everytime I want to update the thing.
Similar issue, wifi wouldn't connect, therefore no spotify/speaker connect (the main reason for going for this bar) for the last 4 months. Wish I'd gone with Sonos 😕
Did either of you fix this issue? same thing happened to me today.
You have attached your query to three post discussing the same issue, two are from 2017 and one from 2022,
the likelihood of you getting an answer back from those oyou are asking is pretty slim I would have thought.
Although I could be wrong.
You might be better off starting a ne thread.
The last firmware update for your soundbar was released in 2021.
Here it is,
So what happened and why are you only now updating the firmware.
If it is completely unresponsive then the only course of action would be to have it repaired.
And who knows how much that will be.
Did you buy it new that model is over 10 years old.
As the posts you have joined with are between 3 and 8 years old
that only shows that updating was a problem for only a few people.
Are there many other posts about the same subject, it would seem strange of Sony to keep an update available for 4 years that is known to render its product(s) unusable.
At any point during the update process could there have been a loss in power to the soundbar or if you were updating direct to the soundbar via Sonys servers was the internet connection broken at any point.
Hi @kameron7, as a last attempt, try to disconnect the soundbar for 2 minutes then connect it back to the TV. Then reset it to the factory settings by following the steps in page 53 here: https://www.sony.com/electronics/support/res/manuals/4570/45701182M.pdf If you're still facing the same issue, you can locate the nearest authorised service centre to you using this link and contact them to arrange a repair: https://locator.sony/en_GB/servicecenters/?zoom=5&latitude=54.29088&longitude=-2.37305
