Hi
I have Sony TV with ARC and Bravia Sync and I have connected HT-NT3 Soundbar.
The connections are:
HT-NT 3 (HDMI 1/ARC) ---> SONY TV (HDMI 1 ARC)
HT-NT 3 (HDMI 2) ---> Sattelite receiver (HDMI)
HT-NT 3 (HDMI 3) ---> PlayStation 4 (HDMI)
HT-NT 3 HDMI 4 ---> Chromecast Ultra (HDMI)
For the first couple of months every this was working great. Bravia Sync discovered HTNT-3 as AUDIO SYSTEM and the rest 3 devices as PLAYERS (1, 2 and 3).
Since the last update Bravia Sync starts showing HT-NT 3 as AUDIO SYSTEM and PLAYER at the same time, so it limits additional players to only 2.
Now Bravia Sync shows:
Player 1 - Sattelite Receiver
Player 2 - Playstation 4
Player 3 - HT-NT3
Audio System - HT-NT3
As you can see the Chromecast is no longer discovered by Bravia Sync.
Is there any way to stop Bravia Sync discover HT-NT3 as a PLAYER so I can gain control of my Chromecast again?
Thank you
Hi there
Im unsure on what TV model you have, but see if this works or helps:
If this doesnt work and considering that it started happening after a firmware update as you described, I would suggest a factory reset of the TV and HT-NT3 and set it back up again.
Hope this helps.
