Not sure if anyone can help as I think there may be a problem with the unit, but it is less than 2 years old and has started acting up. Very disappointing for such an expensive product. Firstly, I can't connect any devices via Bluetooth anymore. The remote control does not function correctly in that pressing the Home button does not produce anything on the Sony TV screen. When highlighting the HDMI port that the sound bar is connected to via the TVs input button, the screen is blank. Switching on the sound bar with 'TV' as attge default renders the actual TV mute. So many issues that have suddenly just appeared! Batteries in remote are new. HDMI cable is fine. I think I may have to take for repair unless anyone can advise a workaround. Many thanks in advance.
Keep us posted on how you get on with Sony. They basically fobbed me off, despite an attempt at escalating.
Considering notifying BBC watchdog to see if they'd be interested , but very much not expecting the anything 😊
Not found a good replacement soundbar... They're either small and cheap, or expense and big 🤔
Same issue for me. Mine died a year in to ownership and John Lewis can't source the parts to repair it under warranty.
I'm now left needing to find a replacement with the same features and with similar dimensions to fit within the limited space I can dedicate to a soundbar.
Very disappointed with Sony, I expected more.
Yeah, thankfully I received a full refund in the form of a credit note to purchase a replacement. I'd prefer to have had the money so I could shop around but it's better than it could have been.
Same problem here! Seems like a firmware issue however I can’t even get to the firmware update option to upgrade it!
crazy...
