I have just purchased a Blu-ray DVD BDP-S3700. The remote will not control the volume to match my Samsung TV. I have heard that you press the green remote button and enter a Samsung code. But their are no numbers on this remote. And I have no idea what I really have to do to get this Sony remote to work the volume, when playing a DVD. Also have no idea what the Samsung TV code is anyway, as their are so many?
Their is no idiots guide for people to easy understand. Do I just ignore the Sony remote match, and just use the Samsung for volume control. This is so annoying, when other DVDs i have had work fine, that do not match using a different TV.
Hi there,
Welcome to the community.
We will check this and update you when we have more information.
Maybe our members will be able to offer some tips until then.
Best wishes,
Ed
Hi talkingheads,
Make sure that Control for HDMI is enabled:
Manual page 28: https://www.sony.co.uk/electronics/support/res/manuals/4579/a5b46d9c8e6f4597786f4507357935d2/4579664...
There should be a similar option on your TV, this will allow the player to control your TV.
Win_88
