Hi there, I did have the soundbar Soundbar HT-A3000 before, where I was able to manually setup the distance of the soundbar, subwoofer and rear speakers. Now I have upgraded the soundbar to the HT-A8000 and did the initial setup using the Bravia Connect app, but can't find the option to manually setup the distance, only the automatic wizard for the sound field configuration. does anyone know how to manually setup the distance on the Bravia Connect? or is that not an available option? Thanks all.
