Can Anybody advise me where and how to start planning my media/audio system for my new house?
Ideally i would like for tv in livingroom (+ Surround Sound), tv in kitchen both with spoken command and video call capabilties and linked to a media storage facility with control from both rooms.
Also would like a Good Sound sytem to be available throught downstars. preferably with embedded wall speakers.
maybe two external speakers for the garden.
This would be a long term project , but im trying to prioritise and getting my melted.
Dont really know where to start TBH
Thanks in Advance
G
@chunx78 wrote:Dont really know where to start TBH
Hi there,
That statement above, is really the problem. You have an idea of what you want, but without knowing your full requirements, it is hard to advise you. What you need is to sit down with someone and plan what you exactly want/need for proper advice.
I'll give you a couple of examples
So basically, my advice is this
If there are specific questions, by all means post on these forums.
Hope that helps
Hi there,
Hope that helps
