Know some if it has autotext when but transfer from Cambridge Audio 851N Musicstreamer to Sony MDS-JE780 using AudioQuest Vodka Optical Cable
Hi @bhaldborg,
Not sure if I've understood your question correctly, but in principle it should work if the information needed is included in the stream.
Hope this helps.
Cheers,
Cass
