Hi, please can some kind person put me out of my misery!
just bought xd559305 tv and I am trying to connect it to my home theatre system model BDV E300, I have connected it using a hdmi cable (although I am not sure the HT is arc compatible) I have also connected a digital optical cable from the HT to the tv but it still will not play the tv sound through the HT system, it will however play sound through the HT speakers if I play a bluray disc
please can someone guide me through the whole thing from connecting the cables to any settings I have to set on the tv and HT system, I also have the Virgin TiVo box connected via a hdmi cable which works ok but no sound through the HT system speakers.
thank you in anticipation.
