Got a new bluray BDP-S780 and like many others on here I can no longer access BBB iplayer . The iplayer menu will appear but it is formatted incorrectly and there is no PLAY function for any programmes, tv or radio.
The iplayer was a big selling point for this bluray so...
Hopefully if I start a new thread then sony will be persuaded to tell us what has happened?
Thanks
Paul
Hi
Sounds like a different issue to many of the others & the BDP-S185 issue is very different. Have you tried just running a factory reset & formware upgrade as this just sounds like a software glitch which can be fixed without too much bother.
Thanks
