Hello
I have been using two Sony NSZGS7 for streaming Filmon for the last four years. Yesterday neither would work correctly. I can load the main filmon screen and select a channel but it will not play. A description of the selected channel is displayed along with a small screen shot. As this has affected both players at the same time I assume it is not a fault with the units. Today I carried out a full factory rested on one unit but the results are still the same. I am able to watch Filmon via my PC. An internet speed test shows just over 80Mbps, so not a problem
Can you offer any help with this?
thanks
Hi there
If its not working still - I would advise you to contact the people behind Filmon as it sounds like they may have an issue with their app.
I believe their support email address is:
support@filmon.com
Hi
Its not the app as it still works on my Pc's, it may be that as the Sony uses Chrome this no longer has the correct support, although I have used Chrome on a PC to watch it..
I emailed the support day's ago but did't get any response.
I tried loading the Android app on the Sony and this works, the only problem is the picture is abpout 1/8 of the screen
regards
