whenever we put a DVD in on the front on DVD player there's a letter T and then the 00.00
Dvd will play for 21 seconds and cut off tried everything possible from the manual help please anyone
Hi there
I have had a look at the service manual for your dvd player and cannot find any reference to that error message.
Really the only advice i can give is to ensure that your discs are clean. The DVD lazer cleaners you can buy may help, but may not even be the issue. And i find that they are not very good either.
As this DVD player is going on 7 years old now (unsure how long you have had it), if you cannot get it going, it might be best to replace it. Approx £30 for a new DVD player or about £60 for a bluray player.
Hi there
Please reply back with the model of the DVD Player.
Hi there
