Does anyone own an x800m2 and HTZF9 or other Sony Dolby Atmos sound bar and found when playing a 4k Atmos disc by pressing display on the remote instead of indicating onscreen Dolby Atmos mit shows Dolby True HD? Customer support are unable to give me an answer..
Hi there,
Hopefully a community member can help with this.
Best wishes,
M
Hi there M, thanks for thi8s. stragely enough it's not the player as I have a second on an x700 in the bedroom with an HT9000 soundbar . It's exactly the same on that one too
Regards,
Briasmit9
Have you tried connecting the player to the TV directly since you have ARC enabled? I believe this should resolve this issue.
hi there,
no I haven't as the soundbar is a Sony HT ZF9 which is a Dolby Atmos soundbar. Stragely enough on the soindbar display it does say Dolby Atmos-Dobly true HD 7.1 24fps. It's only says Doby Tue HD 7/.1 on the Sonty X800m2 player. Will try this, thanks
