I have a DN1050 av receiver and I am currently having some fitted furniture in the living room where it is installed.
The fitted furniture will be an enclosed cabinet for the amp, however I have been researching clearance and cooling
Can anyone confirm if the av receiver will be OK in an enclosed cabinet? How much clearance should I give around the amp? Do I need to install and cooling fans and if so what is the max temperature the amp can run at?
I may upgrade to the 1060 in future if that makes a difference
Hi there
The more you push and drive an AV Receiver the hotter it gets. This is why there are many vents in the casing itself. In an enclosed cabinet, you really need to find a way to remove this unwanted heat. The following guidence is from the manual, however I can not find any specifications of operational temperature, max temp etc.
