I have created a Data DVD (16x R+) with 3 DivX files. My DAV-DZ660 plays the viedeos without problems but it will not play the end of the files ? Instead it jumps to the next video.The files DOES include the end of the films since they can be played on a PC.
The amp DOES play normal DVD films an I am fully satiesfied...but it't a bit strange that onlyu the DivX files cant be played in their full lenght.Sony DK support has asked my to try to reset to factory settings. I have tried that - but no luck :
Its cutting the ends of movies off? Maybe its something to do with the way those elements have been encoded which is effectively causing the device to basically error. Does it happen if you playback via USB also\?
