Sky Q box is connected to HT-ZF9 sound bar by HDMI, 'IN', and 'OUT' and to my KD55-AG8 Bravia TV to it's HDMI3 (ARC) connection.
Is it normal to expect a 12 second delay, which I have, before I see and hear anything on the TV.?
The Sky remote button switches everything on.
Hi there,
Have you updated to the latest firmware?
Best wishes,
M
Yes
TV is on auto updates, and recently received notice the sound bar required an update, which I did. The issue was before and after update.
The issue lies with the sound bar, as I when I switch on using the sky remote I get a blank screen on the TV with AV input info, and a scrolling message on the sound bar, 'Please wait' appears. But a wait of 10-12 seconds seems a bit long?
Hi Abadge,
Since the sound bar is already connected via ARC, you can directly connect Sky to the TV. Could you try this and share with us how it went?
Cheers,
The_Black_Rose
