II have just bought a Sonos Beam how does it connect to a Sony Brava KDL-D3000?
Hello @davidfigg,
your Sonos Beam doesn't seem to have an optical input.
According to the SONOS website it is meant to be used with TVs, which support ARC (Audio Return Channel) via HDMI. Since your TV does not support this function, you can't connect your soundbar to your TV as far as I am concerned.
- Nic
