Hi all just tried to activate my lovefilms account for viewing through my s370 and cant register it with My Essentials as i cant see the activation code it just bsays that its been registered, any ideas how i can view the code, thanks in advance
best regards R4d
Hi Rich4d - Best way to get the code is try and start playing a movie on Lovefilm and it will give you the error screen/splash screen with the code displayed.
Thanks
Go into the "Top Menu", scan across to the right and down one. You'll see an icon saying "activate enhanced features". click on that and a code is generated. Keep the menu open, as the code is refreshed every time you reopen the icon.
I hope this helps.
The network icon doesn´t show anything. How can i obtain the code registration for Amazon??
