Hi there
Can you confirm that everything is connected correctly on the AV Receiver, espcially the speakers?
Try performing a factory reset - Whilst AV Receiver is OFF, press the power button on the front of it, for 5 seconds, until "Clearing" appears. Then "Cleared" should be displayed. Then switch it on again.
