I enjoy classical music and the best online site for showing live and old classical TV broadcasts that I have found is at www.medici.tv which is available in the UK in English although I think it is French based. I am thinking of replacing my existing Sony BDP-S360 blu-ray player with the BDP-S570 which has internet access and is supposedly able to access BBC iplayer, if it will similarly access www.medici.tv then that would be the final reason for making the purchase.
Thanks for any help
Alan Dawes
@SERVEURSTUPIDE I didn't look back at all your trying so I didn't check the chromecast options.
Be aware that I removed your personal contact from your reply since it's forbidden by community rules (and not so convenient for you ).
Regarding the .apk and android compatibility in general, the problem is the TV ... is a TV : it doesn't support touch for example, so it's up to the developer to adapt it and declare the compatibility to the google store so that it appears directly on your tv google store. Said so you may also try to contact medici.tv to understand if it is in their roadmap to create a version for android TV. Most of the app in any case still continue to work as is, but it is not guaranteed (some do not even install at all)
Regarding .avi , it is a completely different problem related to Sony not supporting (and not willing to pay the fees) DivX since a lot of time (not strictly related to Android). Also here in any case due to the flexibility of the platform you have several options:
Dear Roobb
Yes, my address was included by my mailer in my preceding message, It was a mistake, I should have removed it. Sorry for violating the rules of the community and thanks for making the appropriate correction.
As the preceding message, your latest message if full of good suggestions.
- Yes, it would be a good thing to contact Medici.tv to ask them why their site does not work with Android TV.
- Concerning the reason not to declare compatibility with Android TV, personally I do not find the "no touch" argument so convincing: it is easy to add a mouse to the TV set an click on icons or buttons. This sounds like a good excuse. What really matters is the purpose of the application. For instance, I undersand that it is not especially useful to install a GPS on a big TV set!
- Thanks for the expert info concerning avi files.
- My two Synology Nas are not "DS play" models, and I do not think they can make any real time transcoding. Maybe if I add some software to them, I do not know.
- Yes, I can convert file formats. Personally I use Nero, which I have been using for years, but they may be better solutions. Still, because I have so many files, I would like to try and avoid this operation.
- I did install VLC on the Sony TV, but I do not know how to make it use DLNA and show the media files on the other devices.
- After a few days of tests, my personal conclusion is that DLNA is not a reliable system for a naive user like me. I am a scientist, but not a computer person. The solution to my problem is probably to buy a small WIndows computer in a box, and use it with Windows Media Player (which seems to work all right with DLNA).
Best and thanks again
It's a pleasure to discuss with you. I don't want to argue regarding android tv differences it's a Google issue but be sure that is not complex, but not really easy too, cover the possibilities of a tv; even tablet and smartphone are different!
Please do not use WMP!! If you choose to have a pc doing the dlna server job - as I do even if I have a NAS too - go for serviio www.serviio.org ; BTW Windows Media Player is not able to transcode your videos, so for you it's useless.
I cannot try Vlc myself but other say that now can access dlna server, look for some server search option. About kodi i'm sure you can
Happy listening!!! it was a pleasure to help you
