I've just purchased a new STR-DN1080 and connected it all into my home cinema setup, replacing my existing AV amp.
It seems to be faulty - in the 'Easy Setup' menu, the speaker auto-calibration can't be selected, and instead says 'Not in use'.
It's also greyed-out in the 'Speaker Setup' menu.
I don't have the unit in Bluetooth 'transmitter' mode, and I don't have any headphones plugged in.
It's like the STR-DN1080 just refuses to believe I have any speakers connected.
If I go into Options - Soundfield from one of the input sources, it only shows Headphone (2Ch) and won't let me select anything else.
If I *do* plug any headphones in, I don't get any sound coming out of them either.
I've already logged a ticket with Sony Support, but has anyone else experienced anything like this?
I have of course tried turning it off and back on again
HDMI pass through seems to work fine, and the Network setup completed fine. It just won't acknowledge my speakers exist!
Hi @feline1,
We would like to know if you were able to resolve your issue already or if you still require advice.
Cheers,
Dutchice
Hi @feline1,
Sorry to hear about that. I think that was most probably the best course of action. Performing Auto Calibration should basically work out of the box. Specially after restoring the device to factory default settings.
Keep us posted when you receive your replacement unit.
Cheers,
Dutchice
