I have a problem whith my bluray player sony BDP S-6500.
I can't play files .mkv whith h.265 (HEVC) codec. Is there a solution?
I would prefere not to spend my life converting files into "acceptable" formats...
The firmware installed on the player is R0218.
Thank you
Hi there
I cannot see anywhere in the specifications or manual that this bluray supports the HEVC or H265 codec.
The following files/codecs are supported on the BDP-S6500:
