My brand new home cinema plays one maybe two songs on youtube before freezing on loading... i can return frfom the remote to the main menu but thats all i can do. If i try to open another app i have no succes... doesnt even open it.. stuc on loading. Checked the wireless connection and all good. Only way is to stop/restart system. Any sugestion would be appreciated.
Hi there
Is it only freezing on YouTube? Does iPlayer for example work ok without it freezing up? A couple of things to try:
If it still does it, can you test using an ethernet cable - just to rule out a wifi issue or conflict? Although it seems to be not internet related but more related to freezing of the actual player itself.... But worth a test though in my opinion.
