Hello!
I just set up my BDV-N7200W to my new Samsung smart TV. I connected the ARC port on the TV to the ARC port on the Sony. When I turn on the Sony, the speakers make this crazy high pitched noise / squeal / whine. It's ridiculously loud. Sound from the TV doesn't come through and it happens even when the TV is off. All I get is this screamingly loud sound.
What can I do to stop this? I'd rather not have to use optical on my brand new system.
Thanks!
**EDIT** It turns out that it makes this noise even if nothing is plugged in, so I'm assuming it needs to be returned.
