All,
when i try and launch anything from iplayer on my BDV-n590 i get :
SSL Alarm Display
The security of the target peg cannot be confirmed. An error has occurred during server authentication
i am connected to my virgin media wireless..
anyone got any ideas. It is the latest firmware and i have tried both network and system resets to no avail. It is getting really quite frustrating
cheers
Steve
Hi there
Ive been doing a little bit of research on this one. At present there is already a thread in regards to this problem:
A factory reset seems to have cured the problem with some people, but not all.
As an experiment, can you try the following:
If you go to reset and reset "All" this should cure it.
