I'm looking at buying a BDV-E670 Home Cinema system, but would like to be able to play the Audio in a separate room.
I'm not too bothered about rear speakers, so could I use the TA-SA200W module to play stereo sound instead?
If this is not possible, what other Sony S-Air products would be compatible (not just the AIR-SA15R)
The Sony website is a bit confusing
Thanks,
Nods
