My system is working but any of the sound buttons on the remote just get NOT USE on the screen
Hi hobby750phil,
Probably you haven't enabled sound mode:
The sound mode can be selected only when [Sound Effect] is set to [Sound Mode On] (page 49). When [Sound Effect] is set to other than [Sound Mode On], the sound mode setting does not apply.
Hi Peter.
Thanks for that. I will certainly give that a try.
Phil.
Brilliant.... So simple when you know how.. Thank you Peter I have all my settings now.
Phil Dipple.
