Does anyone know if it is possible to set up this player with fixed IPs? The internet setup config seems to only contain DHCP assigned IP numbers. Has anyone managed to set static IPs? If so, how? Thanks.
Hi Stephan,
We're taking a look at this for you now, and we'll be back in touch soon.
Thanks,
Owen
Hi again Stephan,
The IP address usually needs to be assigned in the router – not the player. Could you try it this way, and let us know if you have any further trouble?
Thanks,
Owen
