Since I have had it from new the menu screen on my BDPS6200 does not flow or scroll freely, it moves from icon to icon very jerkily. Is this a fault or a settings issue. My outgoing BDP S350 scrolled perfectly as does my PS3....
Thanks for any advice
It should flow smoothly though whether this is actually a fault I can't say for sure.
Maybe the best option would be to RESET your device and see if that clears the problem.
Here's how:-
Please do come back and let us know if this helps.
