I have an BDP-S470 Blu-ray player.
When I'm trying to play MKV movie, the player writes that "The file is corrupt or UNSUPPORTED".
Data from the first film:
Codec: H264, MPEG4 AVC (part10) (avc1)
Resolution: 1280x780
Frame rate: 23.976215
no problem
The second film details:
Resolution: 1920x1072
Frame rate: 25
Data from the third film:
Resolution: 1280x720
Does anybody have ideas?
The BDP S470 Blu-ray why do not know the exFAT file system?
Did you encode the movies using the latest version of handbreak (0.9.5)? If so, this may be your problem. Selecting "same as source" for your frame rate results in a variable frame rate that the Sony players don't support. Sometimes mkvinfo reports the frame rate on the encode as 25fps, even though it's actually variable.
Try re-encoding but select the actual frame rate from the pulldown (find the frame rate from the analysis log) but make sure you don't tick the variable frame rate!
