Hi Sony Friends
How can I get the BDP S373 to read files on an eksternerly disk? I've tried FAT 32 and NTFS! ... FAT 32 worked great, but my files are a lot bigger than they can support!!!!
Can I change the software? Or is their an other way?
Hi there
Unfortunatley FAT32 is correct. However if that doesnt quite fit your requirements, you can install a program on your computer called Homestream, and "stream" your media files to your bluray player.
http://www.sony.co.uk/homestream
hope that helps.
Hi there
hope that helps.
