Hi, can anyone suggest a good surround speaker system which I could buy to use with my BDP-S370? I've heard I'd need a 7.1 channel set up to get surround on blu ray discs, but I'm a bit out of my depth to be honest.
Thanks for any help.
Paul.
you will need more than just speakers im afraid, you will need a dedicated home cinema Amp as well, you could start off with 5.1 to get going the add the other speakers later to get 7.1 or true HD.
