Has anyone else had trouble following the recent upgrade where the S1100 blu-ray player doesn't run opera apps anymore? And when you try to open a SEN app, it says 400 bad request. I've been considering trying to re-upgrade with a cd using the UPDATA_M1R0138.ZIP I downloaded from the Sony website, but I'm afraid to brick the player. I haven't found enough technical support to guide me through the process.
Any help would be appreciated. I'm super frustrated because I really wanted to be able to use some of the apps.
