Well it seems that this is a recurring problem from what i have discovered from various sites, as my bbc iplayer has now failed to work saying no documents found, and it was working fine at tea time as my grandson was watching milkshake on it.
And as for the opera tv store that hasn't worked since i did a network upgrade when i bought the blue ray player 3 weeks ago, and don't get me started on SEN!
I have reset everyting and rebooted everything, and still nothing, i thought being a network engineer with 2 degrees in computing , this would be easy but no.
Evverything else works fine, demand 5, netfliks, lovefilm, crackle etc if i can't get this sorted then i'm afraid it's going back for an exchange and if it happens again i will be replaceing it with a different make i thought sony where a good brand they always used to b
COME ON SONY PULL YOUR FINGER OUT !!!!!
I have a BDP S-5100. Had it one month and also stopped working over the last couple of days.
Loads a white screen on iplayer and wont connect to SEN.
Do Sony have any suggestions on this issue?
20/09/13 07:23 UK Time - Email sent to support - will post response if / when received.
I received this device as a gift 2 months ago, it has the latest firmware installed and has been factory reset to try and resolve the issues already.
1. Opera Apps
On the specification page on your web site it states that Opera Apps are not supported and when I try accessing it a message is displayed showing 'not supported' however within community.sony.co.uk many users state they have been using Opera Apps on this device and when they have started receiving this message they believe the device to be broken. Should I be able to access Opera Apps ?
2. iPlayer
Untill 2 days ago this worked perfectly. Now it shows a no documents found error and then a page cannot be found web page error. Demand 5 works so the internet connection is not at fault. Within community.sony.co.uk it seems I am not the only person to experience this.
How can I fix this ?
3. ITV Player.
Will itv-player ever be supported on this device or has my wife bought me an out of date/no longer supported device ?
Thanks for your time.
Same thing here.
BDP S1100 (provided by Lovefilm to replace an LG one that will lose the LF app in October)
Received an OTA update last week and since then, have been unable to access BBC iplayer or BBC News.
I have tried resetting the box and leaving it unplugged over night etc.
(I can also confirm what others have said - half the apps on this thing don't work anyway - can't even connect to operaTV or Accuweather)
I'm relieved to see that I'm not the only one experiencing this.
NetFlix, LoveFilm and Demand5 are working fine.
