Hi all,
Have any of you encountered this issue with the BDP-S7200 Blu-ray player from Sony?
This problem only seems to occur when watching content on Demand 5 Catch-up Services.
Screensaver will activate at random intervals with no set pattern however you can still hear the soundtrack to whatever you're watching. For instance this evening I watched a movie and after 31 minutes the screensaver appeared and then again 26 minutes later and once more at 17 minutes later. This has happened with all Demand 5 content that I've viewed so far. To dismiss the screensaver from view I press the down arrow.
In a private PM forum member Quinnicus has suggested that I could just disable the screensaver which is probably the best solution however having only bought this device last 2 weeks ago I am concerned this might indicate something more serious. I shall await any further feedback here for now.
For those of you who may be considering buying this device you should not be unduly concerned, it's a fine piece of kit which I can thoroughly recommend. It has also just been awarded Best Buy in the £200-£300 price range by the respected What Hi-Fi Magazine.
Hi MK_Slinky
Just to let you know, Im trying to chase up the progress of this as I did report this to Sony. Hopefuly I;ll get some feedback soon.
@Anonymous
HI there,
Many thanks for doing this for me. I guess the firmware update didn't fix this after all?
Cheers.
Hi there
No, the FW update wasnt about addressing the screensaver issue that you have been experiencing unfortunately.
OK, thanks for the info.
I wonder what this fixed though?
"BRAVIA Internet Video improvement"??
Shame Sony aren't more specific about fixes like other manufacturers!
Hi there MK_Slinky
Unfortunately you are not going to like the current news. Currently this particular problem (Screensaver issue on Demand5) is un-resolved, and unfortunately its unlikely to be resolved (at least any time soon).
So, the only advice/work-around is to disable the screensaver when using Demand5.
Ah yes, you did mention that once before but I forgot to try it. I'll test this out later if I get chance. Knowing my luck lately it will still come on even if it's off.
@Anonymous
Sorry this took me a while to test! I can happily report that your work-around solution of temporarily turning OFF the screensaver does indeed work.
Hopefully Sony will eventually fix this though...
Thanks for confirming that the work around, works
