Hey,
Does anybody know any way to view 3D photos in the browser of the BDP-490 3D blu ray player? I've tried them as MPO files, JPS, and as a simple side by side JPG, but none of them are showing up as 3D.
My 3DS shows MPOs in 3D in the browser, but I just can't work it out for the blu ray!
Hi there
Are you referring to the web-browser? Are you able to play them via USB instead?
Pictures can be viewed by USB fine, but I,m tryong to find some way to view them in the browser, so pictures can be easily shared between friends without having to download then view on a memory stick.
The pictures load as MPOs, but are flat images. If I try to do the same thing with my PS3 I just get a garbled screen of text, so it can process the file, but is only ahowing one of the two images.
Don't think its possible as far as I know - the browser is pretty simple compared to computer/tablet browsers and principally there to facilitate IPTV service like iPlayer.
