I have to have my soundbar above my TV as it is my only option for a setup, so my question is about the settings in the setup menu in the soundbar where I should set it up, whether it is placed in front of the TV or behind the TV or under the TV? which setting should i use?
If, as I suspect, it is looking for front/back placement to make a small timing adjustment to the audio, then ‘Under’ represents the same forward/backward placement as ‘above’.
But why not try all three, see if you can tell any difference, and if so, pick the one that sounds most pleasing to you?
Thanks 🙂
