Hello,
I recently bought a Sony BDP-S7200 and saw that it comes with a Mubi application. Unfortunately, if I try to open the app, I get a loading logo for like 3sec and then a white screen appears and I'm unable to do anything (I need to reboot the player in order to use it again).
How can I access the Mubi application using my player ?
Thanks
Hi there
I believe you might need to activate Mubi in advanced features once you register the device in: http://www.sonyentertainmentnetwork.com
Thanks for your reply, I only have these in advanced features :
Can't find Mubi anywhere. I read somewhere that I needed to go to SEN through my blu ray player, but it's not working either.
