Hi, don't know if any body can help here? It's a X800M2 Blu-ray Player.
As in the photo the 'HDMI OUTPUT' says DD 2.0.ch. I have a 5.1ch sound system. Should I be looking at the top info or the lower info, what's is actually being output?
Am I actually getting 5.1ch or 2.0ch?
Cheers!
I wouldn’t connect TV and soundbar both by Optical and by ARC; I’d just use ARC.
And there’s a mismatch between your description of things and what RTINGS thinks:-
https://www.rtings.com/tv/reviews/lg/uk6300
@Lolpo555 you have to consider also that in your setup the s40r soundbar does not support DTS, so this could be the reason why your are getting only PCm from your bluray.
